functions like Applications, Quality, & Design. Support component library development for the internal PCB Design tools... signals multi-layer PCB´s Strong knowledge of modern PCB design, manufacturing processes, and assembly technologies...
, they are looking for an experienced PCB Design Engineer to join their engineering team, taking ownership of PCB layout and implementation across a variety... of complex electronic products from initial design through to production. In this PCB Design Engineer role, you will: • Create...
I'm currently recruiting for a PCB Design Engineer to join a highly technical engineering company based in Tewkesbury..., Gloucestershire. Salary £35,000 - Junior PCB Design Engineer Up to £60,000 - Experienced PCB Design Engineer...
Days Holiday + Flexible Hours Lancaster, Lancashire Are you a PCB Design Engineer or Electronics Engineer...PCB Design Engineer (Training on RF and FPGA) Satellite Communication Projects + Expert Training + Progression + 25...
for an experienced PCB Design Engineer to take ownership of complex PCB layout and implementation activities, working across a diverse... range of innovative electronic products from concept through to manufacture. Key responsibilities of the PCB Design Engineer...
As a Senior or Principal PCB Layout Engineer, you'll be responsible for the design and layout of complex multilayer PCBs (4-20...Senior to Principal level PCB Layout Engineer Location: Berkshire based, looking for relocating candidates. Working...
in electronics and mechanical engineering. Experience in ‘Design for Manufacture’ and have visited PCB and Assembly Manufacturers... and water quality environmental monitoring, electronics design and development, oceanographic research, deepwater oil and gas...
Proficiency in PCB design tools such as Altium Designer, OrCAD, Allegro, or similar software Understanding of electronics... PCB Layout Engineer. In this role, you will be instrumental in designing, laying out, and optimising printed circuit...
Production Test Engineer with a strong Electronic/Electrical engineering background. This role supports the testing and fault.../electronic sub-system and system design, integration and test principles. Good verbal and written communication skills...
, Electronic, Design, Electronics Design, PCB, PCB Layout, Design Engineer, Marine, Maritime, Energy, Oil, Gas, Renewables...Junior Electronic Design Engineer (Training/Progression) £35,000 – £45,000 + Training + Progression + 39 Days Annual...
